Yes.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108592
So FPS has to drop when i'm recording no matter what?
Yes FPS will drop no matter what, but it depends how much it drops. For example if you play at 60FPS recording could drop it to 40-ish on an i3 which is noticeable to some people and you may have to turn settings down to keep it smooth
"Rawr XD"
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108632
Is that cause i'm using dxtory..
Is there a why to edit my videos to 60 FPS??
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108652
It's because you're taking power away from the game in order to record the game.
PSU Tier List | CoC
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108666
Does AMD have program for recording?
GameDVR
PSU Tier List | CoC
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108670
TL;DR
Yes
Since you are using D Xory you can use this to help have less performance impact http://lags.leetcode.net/codec.html
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108742
Is it better than Dxtory
Yes because it doesn't use any CPU power, it uses the H.264 encoder directly on the GPU.
No performance impact really because when you're gaming H.264 encoder sits there doing nothing anyways
"Rawr XD"
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108772
So i should use AMD program, not DXtory ?
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108808
With GameDVR i will not get FPS drop? :D
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108827
When it works, it is miles better than Dxtory, when it works...
https://linustechtips.com/topic/302380-will-i-get-fps-drop/#findComment-4108852
