intel G2030 HELP
Go to solution Solved by wyattzx,
do you suggest any other programs?
CPU-Z.
http://www.cpuid.com/softwares/cpu-z.html
my old PC's CPU G2030 does not go over 2.97GHz and it says it goes to 3GHz Plz help?
post-188554-0-65109400-1422762783_thumb.
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
https://linustechtips.com/topic/302084-intel-g2030-help/
Use a utility other than Task Manager.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/302084-intel-g2030-help/#findComment-4104848
It's likely running at 3GHz. Windows Task Manager is not the first readout I trust personally, since it told me my 2500K was running at 6.7GHz.
https://linustechtips.com/topic/302084-intel-g2030-help/#findComment-4104851
https://linustechtips.com/topic/302084-intel-g2030-help/#findComment-4104883
https://linustechtips.com/topic/302084-intel-g2030-help/#findComment-4104912
