4 way sli/crossfireX scaling is terrible.
3 way scaling is better scaled than 4 way,but still not worth it.
2 way scales pretty decently.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
Why bother? you ain't doin it.
but seriously, 4 way is for those who just don't care about wasting that much money or just filthy rich.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
I think its kinda pointless getting 4 sli unless you want serious bragging rights.
Listen if you care.
I would also not recommend doing it without watercooling the cards. The top three will be completely starved of fresh air to cool themselves with.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
Its all bragging rights and Synthetic benchmarks, OC3D Tom even says that if you are considering running 4 GPUs for gaming you are mental or your just in it for the looks and boasting. I run a 4 way 7970 setup and the 3rd card is almost never used in games, the fourth card sometimes degrades performance or just simply acts as a case warmer.
They dont get that hot actually, just make sure you use reference design and you will be fine, my sandwiched cards only ever reach 80c on Furmark
benchmarking or some very very very high res 3D rendering is the only reason i can see to have 4 gfx cards
Asus Direct CU2 7850 at 1GHz 8Gig G.Skill Ripjaws X memory 1333 AMD 6300 at 4.7GHz(hoping to push 5+ with new cooler) 990FXA UD3 mobo all in a way oversized shinobi XL
