CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($242.99 @ SuperBiiz)
Motherboard: ASRock Fatal1ty H97 Killer ATX LGA1150 Motherboard ($100.98 @ Newegg)
Memory: Crucial 8GB (2 x 4GB) DDR3-1600 Memory ($82.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($48.88 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($359.10 @ Directron)
Case: NZXT S340 (Black) ATX Mid Tower Case ($65.55 @ Directron)
Power Supply: Antec 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ Newegg)
Total: $980.48
I plan to add 2 extra 120mm fans, for intake at front, and do 2k gaming.
Have I committed any major sins which you are compelled to correct using caps locks?
OR is this a magical computer?
(I aleardy have a 250gb samsung pro ssd in my laptop so don't worry about that)
Thanks in advance for feed back
https://linustechtips.com/topic/301655-first-build-blueprints/
I would maybe look at a 980 or 290x for 2k gaming if u want 60fps, maybe look at a devils canyon haswell if its mainly for gaming i5 if other work too then i7 version, if you do go that route then z97 is a must
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/301655-first-build-blueprints/#findComment-4099448
