Razer Blade 14 was a pretty good ultra portable gaming laptop.
Do you guys think that they will announce a Razer Blade 14 ( 2015 ) ?
If not , why ?
If yes , then what do you guyz think will its specs be ?
I would like the blade to have the following specs :-
5th gen quad core i-7 @ 2.5~3 GHz
16 gigs of ddr3 ram
Nvidia gtx 880m
Qhd IGZO Panel instead of Qhd +
Backlit keyboard which can change colours .
Better speakers !
How to make your droids snappier:
The ultimate laptop buying guide :
https://linustechtips.com/topic/301551-razer-blade-14-2015/
Im sure they will announce a new laptop sometime!
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/301551-razer-blade-14-2015/#findComment-4098029
I don't think it'll be a blade 15, since it refers to screen size, and not year. That said, it'll probably be upgraded, but the screen resolution most likely won't be going down, because it would look weird to have a spec decrease, no matter how beneficial it is.
Normandy - Intel Core i5 3470, 8 GB Corsair Vengenace LP, EVGA GTX 960 SSC, Gigabyte GA-Z77M-D3H-MVP, WD Blue 1 TB, Seagate 320 GB (steam), Seagate 320 GB (experimental, second OS, etc), Windows 8.1 + Ubuntu 14.10
Garrus - HP Stream 11
https://linustechtips.com/topic/301551-razer-blade-14-2015/#findComment-4098050
Oops ! My bad !
https://linustechtips.com/topic/301551-razer-blade-14-2015/#findComment-4098100
