Total: $1,500.00
1 x Corsair Obsidian 750D Black Aluminum / Steel ATX Full Tower Computer Case
2 x AMD Radeon SSD RADEON-R7SSD-240G 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD)
1 x ASUS DirectCU II OC R9290-DC2OC-4GD5 Radeon R9 290 4GB 512-Bit GDDR5 PCI Express 3.0 HDCP Ready CrossFireX Support ...
1 x Corsair Air Series SP120 Quiet Edition CO-9050006-WW 120mm Twin Pack High Static Pressure Case Fan
1 x AMD FX-9590 Vishera 8-Core 4.7GHz Socket AM3+ 220W Desktop Processor - Black Edition FD9590FHHKWOF
1 x Western Digital WD Green WD20EZRX 2TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
1 x ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
1 x HyperX Fury Black Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model HX318C10FBK2/16
1 x CORSAIR RM Series RM1000 1000W ATX12V v2.31 and EPS 2.92 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
1 x CORSAIR Hydro Series H100i Extreme Performance Water/Liquid CPU Cooler. 240mm
https://linustechtips.com/topic/301546-build-for-a-friend/
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($126.99 @ Newegg)
Storage: Samsung 840 Pro Series 256GB 2.5" Solid State Drive  ($197.89 @ OutletPC)
Video Card: HIS Radeon R9 290 4GB IceQ X² Video Card (2-Way CrossFire)  ($252.98 @ Newegg)
Case: Enermax Thorex ATX Mid Tower Case  ($24.99 @ Newegg)
Total: $1319.43
Generated by PCPartPicker 2015-01-31 06:00 EST-0500
@stunkcuf
9590 is a joke.
https://linustechtips.com/topic/301546-build-for-a-friend/#findComment-4098065
@Maheshvare Thanks and I agree but this is what we came up with. I will post my build on here soon I'm sure you will like it! :)
@Xaring
I like asus actually, I've done 2 ram's and those were just mobo's that were doa! Out of the other 25 some odd builds I've done using asus mobo's video cards and monitors. But that's my experience!
https://linustechtips.com/topic/301546-build-for-a-friend/#findComment-4098074
Go i5 or i7, less power consumption, more power. Also, get an MSI Z97 board!!! I dont trust Asus at all.
MSI Krait is sick , look at the comment above this one and check out my build ;)
https://linustechtips.com/topic/301546-build-for-a-friend/#findComment-4098075
Do you have pictures of that build would love to see it? @ zappian
I just have this here partpicker:
Total: $1319.43
I Dont have money to build something like this.
https://linustechtips.com/topic/301546-build-for-a-friend/#findComment-4098186
Ya amd ram was I think $40 more and this was the ram he wanted. Over all I think good build so far. I'm worried about over heating! Just got last of parts putting it together this weekend and testing. Put pictures up if people request.
I wouldn't worry. That cooler is plenty good enough to tame that CPU and the GPU has a good custom cooler :)
Area 51 2014. Intel 5820k@ 4.4ghz. MSI X99.16gb Quad channel ram. AMD Fury X.Asus RAIDR.OCZ ARC 480gb SSD. Velociraptor 600gb. 2tb WD.
https://linustechtips.com/topic/301546-build-for-a-friend/#findComment-4099313
