BlueScreenView - BSOD help
Solved by Master Disaster,
HAL = Hardware Abstraction Layer
0x124 = General Hardware Error
Primary cause of this error is a bad OC so if you've got any OC in place remove it.
Test temperatures of both CPU & GPU to ensure system isn't overheating.
Next run a memory test, grab memtest86 and run it for at least one full pass (its usually better to do this overnight if possible)
Update any outdated drivers, especially RAID drivers.
Finally check out this page and follow its steps
