Hey guys! Could you guys please rate my first build?
- MSI Z97-G43 Gaming
- i5 4690k
- EVGA GTX 970 SC
- Cougar 700W PSU 80 PLUS BRONZE
- 8GB DDR3 Corsair Dominator
- Seagate 1TB 7200RPM HDD
- NZXT Phantom
Thanks in advance!
What is it for?
https://linustechtips.com/topic/301394-my-first-build/#findComment-4096613
Judging by the Mobo saying "Gaming" and the GTX 970... you're using this to stream X rated videos. It's overkill :P
It'll make a good Gaming rig.  Never really heard of Cougar as a company before so I don't know how their products are but personally I would opt for a good Corsair or EVGA PSU and maybe add an SSD for OS.
https://linustechtips.com/topic/301394-my-first-build/#findComment-4097023
- i5 4690k
- EVGA GTX 970 SC
- NZXT Phantom
Thanks in advance!
Good build but I'd change the PSU to a lower watt. 500 Watt is good enough unless you plan to SLI than keep it.
Dominator is a pricey Ram, it's no difference from any other but if you like it than your choice.
Try to place a SSD in your build if possible.
I7 4790K • Corsair H110 • MSI Z97 SLI Krait Edition • Kingston Fury Hyper X (White)(16GB)(1866Mhz) • Crucial MX 100 512 GB • Seagate Barracuda 1TB • Phantek Enthoo Pro • EVGA G2 750 Watt
Asus DRW Optical Drive • TP Link Wifi Adapter • Asus MX279H • CM Devastator Bundle (Blue) • Bitfenix Spectre Pro (White) • Windows 8.1
Galax Hall Of Fame 970
https://linustechtips.com/topic/301394-my-first-build/#findComment-4097038
- i5 4690k
- EVGA GTX 970 SC
- NZXT Phantom
Thanks in advance!
You won't need 700W unless you plan on major upgrades later. Also, for a high-end build for this, you want to go with an 80+ gold power supply. It's just cleaner power delivery, because you owe it to yourself to overclock the parts. Gold isn't that much more expensive than bronze these days, and you'll only need 500W for that particular build.
Also, you REALLY owe it to yourself to get an SSD. The HDD can wait if you can't afford both at the moment, your priority should be an SSD. It doesn't have to be big, a 128 or 256gb will do fine, and make sure it's a solid one. Any Crucial or Adata will be fine. Kingston makes good SSDs too, but stay away from the V300. OCZ has been 100% excellent since being bought by Toshiba.
Other than that, top-notch build.
https://linustechtips.com/topic/301394-my-first-build/#findComment-4097378
This is my suggestion since you didn't specify budget.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.95 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-Gaming 3 ATX LGA1150 Motherboard  ($129.99 @ Amazon)
Memory: Crucial 4GB (1 x 4GB) DDR3-1600 Memory  ($29.98 @ OutletPC)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Drive  ($118.98 @ OutletPC)
Video Card: HIS Radeon R9 290 4GB IceQ X² Video Card (2-Way CrossFire)  ($252.98 @ Newegg)
Case: Zalman Z3 Plus White ATX Mid Tower Case  ($39.99 @ Newegg)
Total: $1295.45
Generated by PCPartPicker 2015-01-31 02:54 EST-0500
https://linustechtips.com/topic/301394-my-first-build/#findComment-4097401
