I have a cooler master quickfire ultimate and it is not working properly, I know that the problem is the cable. Is there any way that I can get an official cable?
BTW i havent got a warrenty
The cable should just be a standard USB miniB cable. You can just use random cables lying round the place. I used them with mine and it works fine. Save yourself the trouble of getting a fancy cable when it might not solve the problem.
https://linustechtips.com/topic/301299-keyboard-problems/#findComment-4094682
