Need help with fresh win7 install
Solved by R4STABAN,
Are you trying some kind of repair install?
Might be related - there is a bug with the windows 7 install that will put the system reserved (needed for boot) partition on a hard drive if it's present when you install the OS to an SSD.
If that happened to you and your system partition is on the storage drive/raid array then any repair installer won't be able to find it if you've only got the ssd plugged in.
If your system partition was on the SSD, or you're trying a fresh install you could plug the ssd into another windows machine and run a cmd prompt
diskpart
list disk
select disk [your ssd]
clean
or do the same on cmd within the installer if you can get to it (can't remember)
I'm assuming this is 60gb SSD + raid 0 + 1tb storage setup
