So here's the deal: I had to reset my bios because my bios was stuck on an option only enabling 3 out of the 4 cores of my CPU. I pulled the battery, switched the jumper and put the battery back in and such. When I turn on the computer, it makes its regular beep, plus 3 short beeps after. I've read that there's a problem with the RAM, which honestly isn't possible because moments before, the computer was working fine.
I really need help with this as it is urgent. I have a feeling I may have done something wrong with the battery replacement or resetting the BIOS.
Motherboard: M4A89GTD Pro/USB 3.0
CPU: AMD Phenom II x4 Black Edition
RAM: AMD Entertainment Edition 1333MHz DDR3 4GB
https://linustechtips.com/topic/30108-computer-will-not-post-3-short-beeps/
Base 64k RAM failure. http://www.computerhope.com/beep.htm
And yes, it is possible. Hardware failure can happen any time.
Is it still there on 2-3?
Okay.
DIMM slots may be dead?
Very unlikely. How did you reset your BIOS? Using the jumpers?
I unplugged my computer, took out the CMOS battery, switched over the jumpers from 1-2 to 2-3. Held the reset button for 30 seconds. Replaced the battery, turned on the computer, and realised I didn't switch the jumpers. THen I switched the jumpers, turned on the computer, and everything went wrong. Beep to boot up then 3 very rapid beeps and no post.
I don't know what the cause is.
