I need to make fresh instal of windows vista on my uncles laptop...But the os is on another partition on hard disk...Since i never did it in this way,what i need to do in order to get the screen where it shows partition and options? thanks
https://linustechtips.com/topic/300992-problem-with-laptop/
what brand is the laptop?
the recovery OS is still Vista
I wont bother much with Vista and use Win 7 ISO instead
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/300992-problem-with-laptop/#findComment-4089915
It's an old acer laptop...Yes,the recovery os is vista,my friend did the job few years ago....But i dont know how to do it since i never did it before (i always did with cd or usb)...He has no money for get new os atm :/ ...
https://linustechtips.com/topic/300992-problem-with-laptop/#findComment-4089961
Use Alt + F10
http://science.opposingviews.com/boot-acer-hidden-partition-8649.html
https://linustechtips.com/topic/300992-problem-with-laptop/#findComment-4089983
So i tried,but all i get its a black screen with "partition 2" and nothing more...the recovery page doesn't show...I tried to download pc recovery to see if there is any other partition
https://linustechtips.com/topic/300992-problem-with-laptop/#findComment-4098060
