I am looking for a PSU that can support a R9 270x, and an A8 6600k, both overclocked. I don't know which PSU models are the most reliable, and my budget is around $60, but if I really have to I can do a little more.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817116023
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182298
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
I have found a few OK looking PSUs above, are they all safe and stable under normal speed and moderate overclocking, and will last a while? If not can someone recommend me a better one at a similar price?
Thanks!
https://linustechtips.com/topic/300824-help-choosing-psu/
Any of them would be fine.
Could be cheaper: http://pcpartpicker.com/part/evga-power-supply-100b10600kr
https://linustechtips.com/topic/300824-help-choosing-psu/#findComment-4087402
Either the XFX or Rosewill is good (haven't had much experience with NZXT PSU's).
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/300824-help-choosing-psu/#findComment-4087404
HALE82 V2 has slightly better Vreg then Corsair CX but quite worse ripple, so about CX-level quality to make a long story short. Nothing fantastic.
"Rawr XD"
https://linustechtips.com/topic/300824-help-choosing-psu/#findComment-4087902
Thanks!
Here you go :)
http://pcpartpicker.com/part/rosewill-power-supply-capstone450
"Rawr XD"
https://linustechtips.com/topic/300824-help-choosing-psu/#findComment-4087906
