Hi guys, I'm looking to make my computer a Hackintosh.
Right now I have Windows 7 and am planning to install Hackintosh on a separate hard drive, so I could keep both OS.
But I'm not sure if my computer build and parts are compatible for installing Hackintosh.
Looking for some help on that part.
CPU = i5 4670k
GPU = Gigabyte GTX 770 2GB
MOBO = Gigabyte Z87X-UD3H
MEMORY(RAM) = Kingston DDR3 1600mhz 2x8GB
PSU = Corsair TX750
CPU Cooler = Shadow Rock 2
STORAGE = 1TB Seagate Solid State Hybrid Drive (MAIN WINDOWS HARD DRIVE)
                      1TB Seagate Hard Drive (PLANNING TO INSTALL HACKINTOSH ON)
ASUS DVD drive
Any advice and tips would be nice first time installing hackintosh.
https://linustechtips.com/topic/300771-hackintosh-build-help/
Hi guys, I'm looking to make my computer a Hackintosh. Right now I have Windows 7 and am planning to install Hackintosh on a separate hard drive, so I could keep both OS. But I'm not sure if my computer build and parts are compatible for installing Hackintosh. Looking for some help on that part.
CPU = i5 4670k
PSU = Corsair TX750
ASUS DVD drive
I'll sell you a modded mac case
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/300771-hackintosh-build-help/#findComment-4086839
Those parts will work fine.  Although if you want to check out TonyMacx86.com, they have a large community of people running hackintosh rigs who will likely be able to provide better advice than this forum.
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/300771-hackintosh-build-help/#findComment-4086860
Should be totally fine with what you have.  I have built 5 Hacks.  Awesome way to go.  OSX for the business side and Windows for gaming.  Check out my thread in my sig.  I'll help when I can.  Tonymacx86 is where I got all my info to build and maintain my hacks.
+1 for another Vancouverite!!
My build:  Leviathan  Case: 900D  CPU: i7 3770K (watercooled)  Mobo: Z77X-UD5H GPU: EVGA GTX 780 Hydro Copper GPU: MSI GTX 780 watercooled PSU: EVGA 1300W G2  RAM: 32 GB Corsair Vengance  HDDs: 1 x 120 GB Intel 330 SSD (OS X); 1 x 256 GB Samsung 840 pro (Windows 8); 2 x 2TB Seagate Barracuda (RAID 0 Data OS X); 1 x 3TB Seagate Barracuda (OS X backups)  Monitors: 1 x 24" Apple LED Cinema (center); 2 x 23" Apple LED Cinema (surround)  Watercooling: 3 rads, CPU, GPU, GPU, MCP655 pump, Lots of fittings, EK reservoir, EK UV Blue coolant.  Updated build: Leviathan 2.0
https://linustechtips.com/topic/300771-hackintosh-build-help/#findComment-4094267
