So whenever I play FEZ, it's almost like burn-in, portions of the screen (vertically) will flicker, even in the pause menu, and it's really annoying.  Is this a problem of my gpu or is it the game?  I haven't seen this problem in other games but should I be worried about it?  When the screen flashes, it can be discolored too.  Usually when it flickers, it will flicker and sown portions of the game, like a portion of the game that is discovered will be popped out in front of the rest of the game screen.
My life is consumed by CS:GO, even though I'm not exceptionally good at it.
CPU: AMD A10-5800K | GPU: Gigabyte R9 270 2GB | RAM: 8GB 1333Mhz HyperX Blu | Storage: 120GB Samsung 850 EVO + 1TB WD Caviar Blue | Chassis: NZXT H230 | Mobo: Gigabyte GA-F2A88XM-HD3 | PSU: Corsair CX500 500W | Cooling: CM Hyper 212 EVO | OS: Windows 10
In order of priority: GTX 970 Strix, 2 good 1080p monitors, i5 4690k, MSI Z97 Gaming 5 LGA 1150, a job
https://linustechtips.com/topic/300612-wierd-graphical-issues-in-fez/
Anyone?  Really?
If the problem only appears on FEZ try to find some game FAQs or people having the same issue, if the graphical anomaly is part of the game, try to find some info too on that just, google it. If you say its only a FEZ problem and other games runs fine, i wouldn worry too much, but just in case MAKE SURE your temps are OK, some cards when overheating can cause artifacts and that is a signal your GPU is being pushed beyond its limits/dying.
CPU AMD FX-6350 @ 4.5Ghz 1.284v Motherboard ASUS M5A97 R2.0 Memory 4x2GB ADATA XPG Gaming v2.0 1600Mhz CPU Cooler Corsair H100i
GPU MSI 270x HAWK Edition Display HP w1907 Storage 1x Samsung 850 EVO 128Gb SSD 1x 400GB Hitachi HDD Case Corsair 450D PSU Corsair CX750M Semi-modular
Keyboard Logitech G105 Blue LED Version Mouse Microsoft Basic Optical Mouse v2.0 Audio 2x Logitech x230 for a Quad-Channel speaker setup OS Windows 8.1
Re-install your GPU driver. (Remove first) then try again.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
