Cable Sleeving Help
For anyone looking at this topic at a future date, I ended up sleeving all the cables to see how it looked. I thought if I don't like it, I can just try to take them out or hide them somehow. I ended up leaving them in, and it didn't turn out that bad actually. I will attach a few photos hopefully sometime if I can convince myself to actually get up and take a few pictures.
EDIT:
I had a picture on my phone already, so I attached that. I took it when I finished one of the cables. I took two 6+2 pin cables and used cable combs to connect them since almost every GPU these days uses at least two six pins, and others use one 6 and one 8. Anyway, it looked pretty nice other than the fact that the CPU cable and the 24 pin cable attached backwards of how I set up the capacitors. I set them up to be hidden on one side of the cable, but since it attached backwards, I did a hot fix and pushed them back through the cables mass to the opposite side. Didn't quite look as good, but it works.
For anyone in the future wondering what the capacitors are actually for, they're to smooth out electrical ripples AT the connection point to increase consistence in the supplied current. Honestly, they really should be in (or on I guess) the actual PSU board instead of at the end of the cable at the connection point. At least I would suggest putting them on the other end of the cable, so they're on the PSU side, but anyone using the cables as they are don't need to worry since they're covered in heatshrink, so using them stock won't be too bad. At least all the cables are black and not yellow and red like other cables I e seen.
TL;DR:
The solution is to either take them off if you're comfortable with electronics, or to try to hide them. Or if you're using them as is, then it doesn't matter because you can't see them anyway. Bam. I'm done now.
