Whenever I playback a video like youtube on a browser (Chrome) or in general a video on WMP it laggs and my CPU goes from 10% to 100% as soon as I play the video. I am using intergrated graphics and two monitors (27" 1080p and 19"900p). The motherboard is an MSI Z77MA-GD45 and has 8gb of RAM. What could be the problem?
Project Restomod (In progress)
https://linustechtips.com/topic/30009-problem-with-3570k/
What happens when you disconnect the one display and do the same thing?
https://linustechtips.com/topic/30009-problem-with-3570k/#findComment-383442
Wait, So no dedicated gpu? I'm not sure if 2 screens is good for 1 cpu (with integrated graphics).
Problem could be anywhere from Your install of the OS, the cpu, something pc related that makes no sense since it just doesn't want to work.
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
https://linustechtips.com/topic/30009-problem-with-3570k/#findComment-383444
Maybe try 1 screen and see if the problem is the same if not then its just the limitation of integrated graphics with 2 monitors.
CPU: Intel i5 3570k 4.2GHz with Corsair H100 RAM: Corsair 16GB (4x4) SSD: Samsung 840 120GB HDD: Seagate Barracuda 1TB GPU: Strix GTX 1080
PSU: OCZ 650W CASE: Fractal Define R5
https://pcpartpicker.com/user/MelchiorVester/saved/#view=RKNXsY
https://linustechtips.com/topic/30009-problem-with-3570k/#findComment-383464
Sounds software related. maybe a virus.
Try firefox. Uninstall and reinstall adobe flash.
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/30009-problem-with-3570k/#findComment-383613
Task manager should tell you what process is using up all of your cpu resources
https://linustechtips.com/topic/30009-problem-with-3570k/#findComment-383617
The whole system is crashing?
https://linustechtips.com/topic/30009-problem-with-3570k/#findComment-383667
