Hellow
I know this is an inposible question but is it possible to use my home wifi some where else like away from home
The main reason is that a clse relitive of mine is in hospital with no internet reception and i have a decent home network The hospital is a block away and thus i thaught that is there any way i can extend internet to there place
Thank you Need help
https://linustechtips.com/topic/300067-need-help/
No, you can't use your home wifi network unless you get multiple super range extenders and place them all along the way from your house to the hospital.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/300067-need-help/#findComment-4075792
That would be a pain in the ass but would actually work.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/300067-need-help/#findComment-4075816
Which isn't.. exactly.. un-doable..
I can also technically run an ethernet wire from my apartment to all of my classes. I would just need about a mile of Cat6 cable to be suspended about 300 feet in the air with a pull cord that I could use to bring it to each class. Oh, and a bunch of repeaters.
PSU Tier List | CoC
https://linustechtips.com/topic/300067-need-help/#findComment-4075876
That would cost a small fortune. Just go with Cat5e, not Cat6.
https://linustechtips.com/topic/300067-need-help/#findComment-4075903
5e would also require more boosters negating that cost difference.
PSU Tier List | CoC
https://linustechtips.com/topic/300067-need-help/#findComment-4075935
