Hey? Mind making a part list on pcpartpicker.com ? Just makes it easier instead of going through all the links. It will also tell you if the parts are compatible.
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/300046-my-first-pc-build/#findComment-4075436
motherboard and cpu are not paired well
go with a 4670k, preferably 4690k + Z97 board
and please use pcpartpicker so its easier for us to help!
https://linustechtips.com/topic/300046-my-first-pc-build/#findComment-4075438
It should be good, but you don't need a Z*7 board for a non overclockable cpu, also use pcpartpicker, and ssd link isn't working
Desktop: i7-4790k, Samsung 840 EVO 250GB, Seagate Barracuda 3TB, 2xR9 290 Vapor-X's (1 working atm), Asus Z97-Pro, NZXT H440 White, 16GB G. Skill Sniper RAM, NZXT HALE V90 850W.
Laptop: Samsung Chromebook 11.6"
Phone: 8GB Galaxy S4
https://linustechtips.com/topic/300046-my-first-pc-build/#findComment-4075447
Looks good, I can tell you're going for red/black so you could also use the corsair h105 instead of the nepton. Equivalent if not better performance. I have it in my pc, love it.
https://linustechtips.com/topic/300046-my-first-pc-build/#findComment-4075460
That case will house the STRIX 970, yes! The motherboard and CPU are not.. equally paired, though. You might want to look into that. I wouldn't worry about an AiO cooler unless you go up to at least a 4670k. Get an air cooler and a better chip! Also, 16GB of RAM is overkill for your build. If you have the money, sure. But for games, it won't really benefit you yet.
https://linustechtips.com/topic/300046-my-first-pc-build/#findComment-4075469
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.95 @ SuperBiiz)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($79.99 @ Newegg)
Video Card: PowerColor Radeon R9 290X 4GB TurboDuo Video Card  ($269.99 @ NCIX US)
Case: Zalman Z3 Plus White ATX Mid Tower Case  ($39.99 @ Newegg)
Total: $804.63
Generated by PCPartPicker 2015-01-28 17:04 EST-0500
The 290x is better bang for the buck IMHO.
I love suggesting builds , i hope you like it OP.
https://linustechtips.com/topic/300046-my-first-pc-build/#findComment-4075491
