Hi I bought a 380i block used and it's missing the nut. The screw that I'm using for 1155 board has 6-32 threads, so the same as the one used in rad. I'm wondering if I can replace the nut by buying a regular 6-32 nut. I'm just asking because to my knowledge that nut is just holding the screw and backplate so they don't move. Is it okay to use a regular hardware store nut?
The nut is labelled 1 in the diagram.
https://linustechtips.com/topic/300033-missing-nut-part-for-koolance-380i-block/
