OK, so if i get a d5 with the built in barbs http://www.frozencpu.com/products/23616/ex-pmp-305/Koolance_PMP-450_12_ID_Native_Liquid_Cooling_Pump_PMP-450.html?tl=g30c107s1802#blank
and stretch 5/8 tubing over them like in linus'es ultimate build guide, and zip tie them, would there be a risk of leakage?
Any advantage/dissadvantage of using seperate pump/res than pump mounted to res?
https://linustechtips.com/topic/299964-built-in-d5-barbs/
Don't cheap out on your PC parts.
It wouldn't be nearly as safe as using a top and fittings. You'd be fine if you do it correctly...but... if you do it correctly
I'd strongly recommend just putting the extra cash into it. As someone in a very similar position to you, trying to watercool on a budget, i bade you great caution
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4074601
Not very likely to leak if your worried a hose clamp will basically never let go of the tube, and as for separating the reservoir and pump it will lessen vibrations transfer to the case with a soft tube link. As for the pump there are versions that also have built in barbs or aftermarket tops you can get to use compression fittings.
http://www.frozencpu.com/products/13148/ex-pmp-132/Alphacool_VPP655_Variable_Speed_Pump_-_HF_Top_Edition_-_Acetal_13123.html?tl=g30c107s1802#blank
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4074640
Yeah I geuss I'm better not cheaping out
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075593
K, I'll get one with a pump top.
I want it to look good.
Now, should I spring extra cash for dual 180 rad, or save 40$ and get a single 180 rad?
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075641
Pump tops are usually the best option since you can always transfer it over if you need to change the pump or have extra inlet and outlet ports for the loop. (most have more than one in and out)
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075643
Yeah, and it looks better.
I'll need 2 more fittings then.
But that's fine.
I live literally 5 min from frozen CPU, so no shipping costs on anything
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075662
Just wondering why are you planning to use 180mm radiators? There is a 180mm silverstone fasn which is decent for radiators but not too many other options compared to 140mm or 120mm.
Dual radiators are a better value than single radiators usually since it only take a bit more material for some extra size but that diminished after a certain point.
Edited by W-L
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075666
Double your cooling for 40 bucks?
Is that even a question!?
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075672
my case is ft05 wich uses 180mm fans in bottom.
Idd have to relocate my hard drive. and atm its non OC CPU only, as i cant afford new MB
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075717
You have to ask yourself what you value more, future expandability or 40 bucks?
I'd go for the futureproofing, it doesnt hurt
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075774
Yeah i guess, im just pushing my budget. Ill have to get an advance on my allowance.
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4075813
I'm not using a pump top on mine. Honestly you don't need to. As long as you have something secure, some people recommend zip ties...I'm using some metal hose clamps. You use a screw driver to tighten them, so you can get them REALLY tight, unlike zip ties. Once you stretch your tubing over the pump (good luck) you'll see how hard it is, and how freaking snug it is. Honestly I expect no leaks by doing this and I'm not wasting $50 + bucks on a after market kit. If my pump was visable I would have done this, but it's hidden so no need to waste $50 bucks on something I want see. I didn't cheap out on any of my parts for my build, and I don't consider this cheaping out either, it's extremely secure.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/299964-built-in-d5-barbs/#findComment-4076034
