4790k Idle temps?
Go to solution Solved by 79wjd,
Those temps are pretty good (if you're overclocked). But considering you didnt reapply thermal paste (which you should really go back and do) those are pretty good......Go reapply Thermal paste right now.
Hey guys, I just got a 4790k with the Asus Maximus vii Hero motherboard and I was just abit curious at the temps I'm getting with my H220x.  At idle its about 20-30 generally and at load (aida64 for 5 or so minutes) its at maybe spiking to 70 on the cores.  I didn't re apply thermal past from the only stock cooler (I was in a hurry when I shouldn't have been)  I was just curious if these temps are okay?
"45 ACP because shooting twice is silly!"
https://linustechtips.com/topic/299845-4790k-idle-temps/
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/299845-4790k-idle-temps/#findComment-4072427
They're fine, you really should reapply the thermal paste though.
https://linustechtips.com/topic/299845-4790k-idle-temps/#findComment-4072432
But putting on the CPU cooler was so haaaard... :(  Took two people to get it on lol.
its worth the effort :D
PROJECT MOGARCPU: i5 4690k @ 4.9 Ghz CPU CoolerCorsair H100i in Pull on top Motherboard: Gigabyte Z97X-Gaming GT GPU: Gigabyte GTX 1080 G1 Gaming Edition RAM: Corsair Dominator Platinum (2x8GB) 2133 Mhz  PSU: EVGA G2 850W SSD: Samsung EVO 840 250 GB HDD: WD Black 1TB Case: Cooler Master CM Storm Scout II
https://linustechtips.com/topic/299845-4790k-idle-temps/#findComment-4072495
