I was wanting to sleeve my cables once I get a modular power supply, doing it myself to save money. Would this kit work for removing of the pins? https://www.amazon.com/dp/B001KQDS6G/ref=cm_sw_r_awd_ufqYub1HV4AR6
I'm getting all of my sleeve heat shrink and cable combs from UPC. Thanks guys!
https://linustechtips.com/topic/299842-cable-sleeving-tools/
Time still is money
Edit: theres a lot of negative reviews, so I think rather not get it
https://linustechtips.com/topic/299842-cable-sleeving-tools/#findComment-4072397
Time still is money
I have plenty of time on my hands haha. I would love to dabble around in modding and learn to sleeve cables myself. If rather take the time to do it myself then pay much much more to have someone else do it for me.
Edit:
Is it really that hard to sleeve? I've watched a few videos and it looks more tedious than difficult IMO.
https://linustechtips.com/topic/299842-cable-sleeving-tools/#findComment-4072402
you might want to get a soldering Iron, solder, crimping tool, and heat gun also
https://linustechtips.com/topic/299842-cable-sleeving-tools/#findComment-4072417
I have everything except for a crimping tool. Any recommendations?
I believe theirs a form post for this topic and you should be able to find everything there but
this is the one I have though
http://www.amazon.com/HT-225D-Cycle-Ratchet-Crimping-interchangeable/dp/B007JLN93S/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1422460283&sr=1-1-catcorr&keywords=molex+crimping++tool
https://linustechtips.com/topic/299842-cable-sleeving-tools/#findComment-4072484
