What are your current specs, and how much are you willing to spend for an upgrade?
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/299704-first-build/#findComment-4070318
slightly over budget, but this should hold you off quite well.
http://pcpartpicker.com/p/xJvrLk
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/299704-first-build/#findComment-4070326
I'd go with something like this. Add a case you like, and enjoy. Slightly over budget as well, but a solid performer.
You didn't mention if you needed peripherals, OS or monitor. I added the OS, so you can get a higher capacity SSD if you don't need it.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($30.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97M-D3H Micro ATX LGA1150 Motherboard  ($101.99 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-2133 Memory  ($63.99 @ Newegg)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($64.95 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.24 @ Directron)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  ($279.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($78.98 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($91.99 @ NCIX US)
Total: $985.07
Mmmm. The K chip is only a few dollars more. I imagine he also needs an OS.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/299704-first-build/#findComment-4070392
Total: $985.07
Thanks, yours is much better.
He also might want to drop another 15-20 on a disk drive for said OS ;)
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/299704-first-build/#findComment-4070477
