Using an MSI Z87 MPower Max AC motherboard, and an EVGA Supernova Nex750B1 Power Supply. The CPU power cable (Which I assume I need for the 4790k) comes with a 4+4 Mulex: The problem is one of the 4's is correct (patterned square/dome tips) but the other 4 is all dome-topped, which doesn't match up with the motherboard. There is a second CPU power cable I was going to use as well, and it is the same way. Do I plug the all dome-top tips into the varied ports? Note that the 4+4s are going into 8 slots. This is my first build with modern hardware (last built before DDR3 was a thing lol) and I'm on skype with my friend and he is confused as well.
The "ATX 8-Pin Power Connector"s: https://drive.google.com/file/d/0BxmbTklAkJ55STE2X3E3MkUzajQ/view?usp=sharing
My friend's attempt at explaining it:
"his problem is (we're in Skype talking about it) that the "cpu connector" has the wrong type of attach. https://drive.google.com/file/d/0BxmbTklAkJ55T3h4MEdKbjJNbFE/view[1][1]as you can see, they are all the dome ones, they don't have the square corners and domed mid on top. edit: the question is what to do, and what that connector is for"
Posted on Reddit http://www.reddit.com/r/buildapc/comments/2tx8co/troubleshooting_my_44_cpu_power_cables_from_psu/
about it but little help was provided, other than help that wouldn't? work.
Looking for help here.
https://linustechtips.com/topic/299634-mid-build-stuck/
Are you sure you are using the right connector? You might be using a PCI-E connector for your 8pin CPU.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/299634-mid-build-stuck/#findComment-4069295
So I plug the 4 domes into the normal slot and it works fine, right? Just wanna' make sure before I run a test and power this bad boy up.
Yep.
EDIT: Here, a picture of the cable. I have the exact same for my 8pin CPU.
post-21359-0-91493900-1422419482_thumb.j
https://linustechtips.com/topic/299634-mid-build-stuck/#findComment-4069394
Yep.
So I've hit two alternative problems I was wondering you could help me with.
1) On the VGA 6+2 connectors (to hit the 8 slot of my 970) one of the connectors is supposed to be a square and its dome shaped. It still snaps in fine. Will that be ok? The original 6 work fine, the odd one is on the 2.
2) My PSU only has 3 VGA slots (a hardwired one and two modular ones), but I need 4 (I have two 970s ready to run in SLI). Is there some adapter I can buy to give myself an extra slot (I'd also need an extra cable I assume, as the PSU only came with 3).
https://linustechtips.com/topic/299634-mid-build-stuck/#findComment-4069523
First one is fine.
You can get molex to PCIe adapters. Search on somewhere like Newegg or Scan to find one.
https://linustechtips.com/topic/299634-mid-build-stuck/#findComment-4069621
