Hello all!
So I've been getting complaints from people I'm in Skype calls, or really any time I'm using my mic, that they can hear a weird buzzing noise, but only when it's under load.
I turned on the "listen to this device feature" under recording devices, and I could hear it as well. My card is overclocked by 100mhz in AMD Catalyst, if that makes a difference
Thanks! ^_^
-Lolz
https://linustechtips.com/topic/299624-xfx-280x-feedback-issues/
Probably best to avoid Skype.
How is that helpful? You're throwing the baby out with the bath water, so to speak.
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/299624-xfx-280x-feedback-issues/#findComment-4069166
Naw it's best to avoid Skpe.
I think not, kind sir, you can avoid Skype if you wish, but we will all keep using it. :D
https://linustechtips.com/topic/299624-xfx-280x-feedback-issues/#findComment-4069372
LOL sure bud sure
Damn straight! ;)
https://linustechtips.com/topic/299624-xfx-280x-feedback-issues/#findComment-4069415
Ya please sir can I have another asspump ?
No, you already have 200 of them. :D
https://linustechtips.com/topic/299624-xfx-280x-feedback-issues/#findComment-4069444
I did not buy nvidia 970 so I got no asspumps sir LOL.
You mate, are truely disgusting. *facepalm* -_-
https://linustechtips.com/topic/299624-xfx-280x-feedback-issues/#findComment-4069470
