Browns because you're less likely to bottom them out.
Clears would be even quieter though as they're heavy browns (harder to bottom out).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/299539-red-or-brown-switches/#findComment-4068060
i had clears they were loud as fuck
Well, if you don't bottom out reds, they're the quietest. If you bought out your keys then clears will be the quietest.
PSU Tier List | CoC
https://linustechtips.com/topic/299539-red-or-brown-switches/#findComment-4068126
Browns usually. The Logitech G710+ uses o-rings so when you do bottom them out they are rubber-y in sound.
https://linustechtips.com/topic/299539-red-or-brown-switches/#findComment-4068384
Reds once you're use to them.
Meh, I was using reds for a few months -- so I was definitely used to them, but I could help but bottom out the keys.
PSU Tier List | CoC
https://linustechtips.com/topic/299539-red-or-brown-switches/#findComment-4068545
