Cpu way too high clock need HELP
Go to solution Solved by AlwaysFSX,
Take out the CMOS battery, put battery back in.
I have an amd fx 4170 and it's been running really badly with full fan for a while now and i just looked at the bios and it's clocked at 4.6 GHz even though I never overclocked it :/ The max clock for this Cpu is 4.2 I think so it's way over and it's using a stock cooler so this is not good! Please explain how I reduce the clock speed in the bios or through software any help would be great!
https://linustechtips.com/topic/299414-cpu-way-too-high-clock-need-help/
In the BIOS try and find the clock speed multiplier and turn it down, usually its in by 100MHz intervals.
My Build
 - i5 4670k @ 4.4GHz - MSI z87m Mobo - 16Gb 1866MHz RAM - MSI R9 290 - Samsung 840 EVO 250Gb - 2 x 1Tb WD Blue - CX600m - H55 AIO cooler - Fractal Node 804 - Lg 25um64-s Ultrawide screen monitor -  http://pcpartpicker.com/user/colec18/saved/9FKXsY
It is an AMD CPU, their base clock multiplier is set to 200Mhz. :^)
Oh, oops I've always used Intel so I'm used to 100Mhz. But the same process should apply just bring the multiplier down 2 or 3 notches down to 4.2 or 4 Ghz.
My Build
nope. its not. i have one. i have the FX-4130. so thats only 2 steps below his. they are 100MHz intervals
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
there's no such thing as a too high clock speed :D
but yeah, if its running hot you'll need to take care of that. CMOS reset should do the trick, otherwise adjust manually.
Reset the CMOS.
Thanks a lot that worked
