R9 290 cooler
Solved by Guest,
Out of curiosity, what other GPU's have reference boards?
I'm pretty damn sure that the TriX version has a reference board, the VaporX doesn't. I'l look up the other models, give me a minute.
This list should have all reference board R9 290s: http://www.coolingconfigurator.com/waterblock/3831109868577
That backplate and that waterblock only work on reference boards, so all those cards should feature the reference board. But before you buy something double check a review just to make sure.
