$600 build for a friend!
Guest
Okay ya'll, it's your time to shine. I have a friends brother who wants to build a PC for gaming. $600 budget. I have some parts like a 300w PSU, AMD A8 6600k, and an AMD Radeon R7 240, all lying around waiting for a build. What do you guys suggest?
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($111.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($71.99 @ SuperBiiz)
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card  ($194.99 @ Micro Center)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($39.90 @ Directron)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($52.99 @ SuperBiiz)
Total: $588.73
Generated by PCPartPicker 2015-01-25 15:43 EST-0500
boom good gpu with a decent i3
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
Do you guys live near a Microcenter?
We are in the US.
If you can get to a Microcenter this build will be cheaper:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.95 @ SuperBiiz)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($79.99 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($61.99 @ Newegg)
Storage: Seagate Barracuda ES 1TB 3.5" 7200RPM Internal Hard Drive  ($46.40 @ Amazon)
Video Card: PowerColor Radeon R9 280 3GB TurboDuo Video Card  ($169.99 @ Newegg)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($35.98 @ Newegg)
Total: $614.30
Generated by PCPartPicker 2015-01-25 15:51 EST-0500
He will need an OS, case. and I would prefer he has a small SSD, and another, larger hard drive.
PCPartPicker part list: http://pcpartpicker.com/p/cLNmBm
Price breakdown by merchant: http://pcpartpicker.com/p/cLNmBm/by_merchant/
CPU: AMD A8-6600K 3.9GHz Quad-Core Processor  ($84.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.75 @ OutletPC)
Motherboard: MSI A58M-E35 Micro ATX FM2+ Motherboard  ($40.98 @ Newegg)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory  ($78.99 @ Amazon)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($51.78 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Best Buy)
Case: Fractal Design Core 1300 MicroATX Mini Tower Case  ($34.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($39.98 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.75 @ OutletPC)
Total: $668.19
Generated by PCPartPicker 2015-01-25 16:01 EST-0500
This build you can use if you give him your old A8-6600K and for mail-in rebates.
If you don't go for the mail-in rebates remove the hyper 212 EVO and get that later down the line
Total: $614.30
what way of exporting do you use for this kind of price brakedown?
Edit: found it already
BB Code
So, with OS and case:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($166.99 @ SuperBiiz)
Motherboard: ASRock B85 Anniversary ATX LGA1150 Motherboard  ($67.98 @ Newegg)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Storage: Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive  ($25.49 @ Amazon)
Video Card: Club 3D Radeon R9 270 2GB '14Series Video Card  ($139.99 @ NCIX US)
Case: Thermaltake Versa H22 ATX Mid Tower Case  ($34.98 @ Directron)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.99 @ NCIX US)
Total: $619.39
Generated by PCPartPicker 2015-01-25 16:06 EST-0500
Do NOT sacrifice CPU power and GPU power for the hard drive.  You can always grab more drives later.  You really want to replace the CPU later?  I don't think so.
I would like to get rid of the pieces I have, if I can.
With mine you can get rid of your CPU and I don't think it will bottleneck the gpu. And if it starts to do you can get any fm2 or fm2+ CPU to replace it with
yeah besides the cpu i wouldnt use anything you have. No offence but they suck. the 240 barely beats onboard grafics of lets say an i5 or something and the 300W spu is only good for build including either no seperate cpu or a a really basic one that you'd use just cuz your cpu has no onboard graphics. You wont run a good gaming system on 300W. even the 960, one of the least energie consuming gaming cards, still want at least 400W to be safe.
i'd also skip the ssd as at this pricepoint you want to put as much as you can into the important thing such as cpu (not in ur case) gpu and 8 gigs of ram (preferably 2 sticks of 4). But as the following build shows it is possible to combine that if yu look for a while.
For the rest id like to refer you to the post ili199 made. i can post mine but he found better deal apperently cuz i couldnt get the 280 for that price. Really thats a great deal, but id personally NOT get rid of the cpu cooler as its way better than the stock one and also doesnt mess up airflow by trowing air all around the case. You can and would probably be fine, but i wouldnt personally do it unless you're sure you are gonna get in in a few months as an upgrade. i mean its a cheap but aawsome cooler, it beats a lot of coolers that are almost double the price
Price breakdown by merchant: http://pcpartpicker....Bm/by_merchant/
Total: $668.19
Yes the price sais $688.19 but keep in mind thats including buying the proccecor, so since you have it already you can deduct about 84 dollars from the total price bringing you within your budget. i'd make a run for this cuz having an ssd AND a 280 in this pricepoint is pretty sweet!
My rig. Case & psu: evga hadron air. Cpu: Intel i5 4690k. Gpu: MSI gtx970 4gd5 OC. Mobo: Gigabyte GA-z97n gaming 3. Ram: 2x4gb Crucial Balistics Tactical @ 1866mhz. Cooler: Noctua NH-U9B se2. Ssd: Crucial mx100 512gb.
Just sell the CPU, 300WPSU, and r7.  Get like $100 (if you can get that much... or even more) and grab an SSD for that.
It is a build for his friend so not his own. And if he does this he is just giving his friend 100 bucks.
 i wouldnt pay that much for it. the psu is worth nothing but pocketchange. the gpu is horrible and not worth much to me either. I'd rather use intel onboard graphics. The cpu is decent, probably the best out of the 3 and the only one id concider.
The CPU cooler can always be added later if you need the overclocking capability of the CPU.
I think my build is really the one to go for as it gives you an SSD and an r9 280.
Your build is the same price as mine.  You are settling for a crappy SSD (yes, the Kinston V-Series SSD is crap), and storage while sacrificing raw CPU power.  SSD's are not a necessity and can be added later on without much trouble at all.  You are also giving him 1TB of storage which is unlikely to be used.
It is not a good trade-off.
Wut?
[spoiler=My PC]
CPU: Intel Core i7 6700K | COOLER: Corsair H105 | MOBO: ASUS Z170i Gaming Pro AC | RAM: Corsair LPX DDR4 16GB 2400MHz | GPU: EVGA GTX 980 Classified | CASE: BitFenix Prodigy | SSD: Samsung 950 Pro 512GB | PSU: XFX XTR 650W [spoiler= Le Other Stuff] Monitor: BenQ XL2411Z | Keyboard: Ozone Strike Pro | Mouse: A4 Tech X7 F4 | MousePad: Ozone
PlayStation 2 | PSP 2000 | Game Boy Color | Nintendo DS Lite | Nintendo 3DS | Wii
Sony Xperia J (Why u so bad D:) | iPod 4th gen | iPhone 4 | Yarvik Xenta 13c (3muchchrome5her)
Pentium B980 | 500GB WD Blue | Intel HD Graphixxx | 4Gegabeytes of REHAM
Current OS: MSX 10.0 ( ͡° ͜ʖ ͡°)Ilikethelennyfaceyouknow( ͡° ͜ʖ ͡°) Windows Password Reset Guide
