Hey guys,
I've come to you now as a last resort.
I've been having an issue where some sites seem to randomly reset my connection when I try to visit them. I've experienced this issue with Reddit, StackOverflow, Puush and LTT (ironically).
I've tried resetting my network using netsh, renewing my IP lease, uninstalling and reinstalling my network drivers, booting with minimal startup, booting into safe mode w/ networking. I've tried on Chrome, Firefox and IE, and the issue still persists. I've tried using my PowerLine kit with another device (my laptop) to see if the issue happens there - it doesn't. I'm able to access those sites fine on all the other devices on my network too.
At this point I'm really not sure what to do other than reinstalling Windows.
Any ideas?
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/298206-random-connection-reset/
many changing the channel of your router and see if that helps and turn on protected mode if you can.
Ah, I should've noted, I am on a PowerLine kit.
I have also power cycled all my gear.
15" MBP TB
https://linustechtips.com/topic/298206-random-connection-reset/#findComment-4049197
Reset as in, the modem/router reboots or your PC randomly disconnects?
Reset as in the connection to the website resets (TCP rst as a response).
15" MBP TB
https://linustechtips.com/topic/298206-random-connection-reset/#findComment-4050705
Are you actually sure you're getting sent packets asking with the RST flag on? Like, verified using tcpdump/wireshark? Sounds like an attack tbh.
Can you reliably reproduce the issue?
https://linustechtips.com/topic/298206-random-connection-reset/#findComment-4052578
Yes, I have checked using Wireshark and the issue is reproducible.
15" MBP TB
https://linustechtips.com/topic/298206-random-connection-reset/#findComment-4054243
