Hi my mate is looking for a basic pc on a small budget , he is not looking to game on it he just wants to perform basic tasks.
He has a hard drive from his old pc so that is not really a necessity.
OS does not need to be included either.
Would be a real help if some of you could link some part picker links.
https://linustechtips.com/topic/298038-basic-pc-build/
Location and budget? and does that budget include a monitor/peripherals?
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($105.75 @ OutletPC)
Motherboard: Asus H81M-D PLUS Micro ATX LGA1150 Motherboard  ($44.49 @ Newegg)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory  ($57.64 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: EVGA 400W ATX Power Supply  ($9.99 @ NCIX US)
Total: $257.86
Generated by PCPartPicker 2015-01-25 11:04 EST-0500
I went with an i3 so he can game and multi task should he want to, but he could save some money by either going with an AMD APU or by getting an Intel Pentium. And as for the psu, I went with something cheap but still good for general use.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/298038-basic-pc-build/#findComment-4045535
UK so in pounds 300
no monitor or keyboard need already has them (sorry forgot to mention)
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  (£78.79 @ Aria PC)
Motherboard: Gigabyte GA-H81M-D2V Micro ATX LGA1150 Motherboard  (£38.00 @ Aria PC)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory  (£51.44 @ Amazon UK)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£31.43 @ Aria PC)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£31.15 @ Aria PC)
Total: £230.81
Generated by PCPartPicker 2015-01-25 16:06 GMT+0000
I went with an i3 so he can game and multi task should he want to, but he could save some money by either going with an AMD APU (15 pounds cheaper) or by getting an Intel Pentium (30 pounds cheaper). And as for the psu, I went with something cheap but still good for general use.
PSU Tier List | CoC
https://linustechtips.com/topic/298038-basic-pc-build/#findComment-4045559
No he does not plan on gaming
Would recommend a nice i5 chip, so he has a good base for any upgrades, maybe in a year he like to game so yeah
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/298038-basic-pc-build/#findComment-4045584
An i3 can handle gaming just fine, so it would make more sense to save the money and just get an i3.
PSU Tier List | CoC
https://linustechtips.com/topic/298038-basic-pc-build/#findComment-4045593
Total: £230.81
Anything elts you could add or improve on as he has 70 pound more to spend , maybe change the CPU to a FX series one or upgrading the case or psu?
https://linustechtips.com/topic/298038-basic-pc-build/#findComment-4045600
FX cpus are pretty bad these days -- especially when most general use applications aren't heavily threaded (heavily threaded application use when on a tight budget is literally the only reason to ever consider going FX).
He could/should get an ssd though -- either 120gb or 250gb depending on how much he'll actually use.
Storage: Kingston Fury 120GB 2.5" Solid State Drive  (£47.00 @ Amazon UK)
Total: £277.81
Generated by PCPartPicker 2015-01-25 16:12 GMT+0000
PSU Tier List | CoC
https://linustechtips.com/topic/298038-basic-pc-build/#findComment-4045604
