Yes, if you have a new fresh install of windows on the SSD, you can completely wipe the old drive. Infact, if you don't delete the reserved partition, you may have boot contention issues since that reserved part is basically the section that tells the mobo which partition the OS is loaded in.
mind you that in doing this will delete all files on the hdd, as natually comes when you delete the partition the files are located in.
NAME: HAF Satlite MOBO: ASUS Maximus Extreme-Z IV CPU: i5 3570K 4.4GHz 1.256V GPU: ASUS 1080Founders RAM: 4x4GB Corsair Vengeance Red 1600MHz 7-8-8-24 PSU: EVGA 750W Gold STORAGE: 1TB Samsung Evo | 4x4TB WD Green Raid10 OS: 10 x64 Pro COOLING: Custom 360rad CPU under water soon GPU too
NAME: Node Box Server MOBO: Intel DB55SB CPU: i5 750 GPU: ASUS 560DC OC 1GB RAM: 2x2GB Corsair XMP 1333MHz PSU: Coolermaster 1000W Bronze STORAGE: 90GB Corsair FORCE Jails| 5x4TB WD Raidz2 60GB Corsair Force Cache OS: Freenas COOLING: Back to Stock
