Hello im having problems with my windows 8.1, Every time i make a folder and put it inside of my harddrive the folder goes straight to my desktop and i can not delete it unless i wanna delete the whole thing. Can anyone help?
https://linustechtips.com/topic/297616-help/
@Tickinginsanity
are you sure your HDD is not linked to your desktop and re routing it there?
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
https://linustechtips.com/topic/297616-help/#findComment-4040260
