Almost done, but can someone please tell me which PSU cables I need to use? This is my build:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($368.32 @ TigerDirect Canada)
Motherboard: Asus Z97-PRO(Wi-Fi ac) ATX LGA1150 Motherboard  ($239.99 @ NCIX)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($153.99 @ Memory Express)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($285.98 @ Newegg Canada)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($408.50 @ Vuugo)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($139.99 @ Amazon Canada)
Total: $1721.75
Generated by PCPartPicker 2015-01-23 23:00 EST-0500
Do I only need an aux CPU cable, PCIe cable, and the 24 pin motherboard power cable? Are there any other cables that I need to use? Thanks :).
https://linustechtips.com/topic/297078-almost-done-first-build/
Total: $1721.75
You also need sata power cables, and molex if you want it.
https://linustechtips.com/topic/297078-almost-done-first-build/#findComment-4032855
That should come with the PSU.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/297078-almost-done-first-build/#findComment-4032882
What is molex for?
It's an older type of power connector.
https://linustechtips.com/topic/297078-almost-done-first-build/#findComment-4032889
Yeah there are a bunch of them but I want to only plug in the ones I need for my build.
Oh yeah, then just the CPU power, PCIE power, 24 pin, and SATA power. I use Molex for my fan controller, but I think they're also used for case lighting and stuff like that
https://linustechtips.com/topic/297078-almost-done-first-build/#findComment-4032890
They all come with the PSU, however you can get aftermarket cables.... But you have to make sure they are specifically for your PSU
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/297078-almost-done-first-build/#findComment-4032896
