Hello all Ive recently been encountering a problem that is really not settling well with me. Alright so recently we had some Comcast technicians come out to my house to install a new modem or whatever. It installed and it worked fine for a few days but so recently almost every night at about 7 the internet does this thing that makes me want to do bad things. http://gyazo.com/f33b280cc3ec22934568a9635f8be8fd this is the problem. About every 5 seconds the ping shoots up causing my Skype calls to freeze every few seconds as well as making smash bros lag at the same interval. I use Skype and smash bros on a wireless connection but I also tested it on a wired connection and sure as Hitler the same ping spikes occurred. are there anythings that I can do to fix this? Any help would be very much appreciated.
That was probably an opinion
https://linustechtips.com/topic/297075-comcast-network-problems-what-a-suprise/
Call Comcast tech support.......? No just kidding. Try restarting your router/modem and see if that makes a difference. If not then you might actually wanna try calling them and complaining. Not sure if they're going to do anything about it though.
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
I don't know how to fix the problem but I would recommend using your own modem and router.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
I restarted it one time and it fixed the problem but the next day it happened again.
As @DarkEnergy said I would just try your own modem or router
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
I have my own router but im not sure if my parents are willing to shell out for a new modem. Is their a way to see if its my modem thats causing the problems?
Ahhh, did they let you keep your old one?
I belive they threw it away against my will because it was "shitty" the pc enthusiast in me died that day they threw away a spare.
:(, well I'm not a networking expert so really all I could think of was to test it with a different modem
but it seems like the wii u might be causing it. whenever i connect it to go play smash it always goes to shit? could the wii u have something to do with it?
Maybe the modem is directing most bandwidth to the device that needs it. That would make sense, have you tried it with just your PC on the internet?
