mac crashing... again: help!
Solved by SIGSEGV,
Yeah, it's a stupid bug in OSX Yosemite which causes incompatibilities with certain programs that try to get what version of OSX you are using, since it was only intended to output a maximum of OSX 10.9.9 it will not be able to tell the OS version correctly, there is nothing you can do about it other than contact the developer of awesomium and have them stop using the deprecated method of getting the version number or getting Tim Cook and pulling his head out of his ass.i have, its in the link
