DayZ resolution issues
By
GhostWindGamer
in PC Gaming
in PC Gaming
Solved by sanderdegrote,
Ok I tried that and windows says it can't open the file
You can use notepad, which is installed by default in windows. But if you want to make things easier install notepad++ and use that, it's much better.
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
play_circle_filled
Latest From ShortCircuit:
