temps
Solved by lx_srs,
are the temperature shown in corsair link correct?? because it sometimes shows my cpu temp as 10degree celcius which is pretty low for a simple corsair h80i and 5 fans in the system.
the temps in the bios however shows around 30c. it is confusing.
I'd trust the BIOS to be honest. Sometimes desktop software can be off. Plus, are you sure 10 degrees isn't the temperature of your liquid or something?
