Like the title says, what do you think the best $50 cooler is. I live in the USA, so I am talking USD.
Thanks,
Keith
Athlon X4 760K | MSI A88X-G43 | 8GB G.Skill Ripjaws 1333Mhz | MSI R7 260X 2GB | Corsair 300R | Corsair CX430 | 640GB HDD | Windows 7 64-bit
HP W2071d 20" 900p TN | Stock Dell K/B | Microsoft Comfort Optical Mouse 3000 + SteelSeries Qck Portal 2 Ed. | Grado SR80i + cheap 2.0 speakers
https://linustechtips.com/topic/29602-best-50-cooler/
I know but there are better performing coolers for $50.
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-377806
Yeah you can just get a CM hyper 212 EVO and spend the rest on something else or save up and get a high end cooler or get a Xigmatek Dark Knight Night hawk ~50$, it perorms extremely well for it's price and it looks really good IMO.
xigmatek-dark-knight-cpu-cooler_install6
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-377815
Which is better for noise/performance CM v6GT or dark knight II. Which fans does the dark knight come with if I want to add a second.
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-378082
if you are going with aircoolers, like me, try to find something like the cm hyper s , with slim fans, so you never have issues with your ram.
I7 3930K @4.4 GHz  /  Asus rampage 4 formula  / 4x 8gb kingston hyperx blue low profile / gtx 980  / 2x ssd 500gb samsung 840 / 500gb 840evo ssd   /  500 GB WD blue /  windows 7 ultimate
my build: http://linustechtips.com/main/topic/133477-750d-finished/
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-378232
Noctua NH-U12P SE2 is very quiet (comes with two NF-P12s).
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-380355
I'm using the Dark Knight currently, amazing cooler for it's pricerange.
Akula  | Dimastech Test Bench | Watercooled | Tri GTX 680's | Build of the Week
Mercury | Caselabs Mercury S3 | Watercooled | GTX Titan | Build of the Week
Armada | Define R4 Titanium | Watercooled | EK Waterblocks | Newest Buildlog
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-383481
I'm liking the silverstone argon series cpu heatsinks. They're pretty cheap and look decent. I bought an AR02 to use in a very small mid tower case.
I cant really provide any performance numbers on the one I bought tho. I can only say it seems good but it doesn't appear to have the largest area for cooling fins. Im also puzzled why they seem like such a reasonably priced item from silverstone. the company that also sells a computer case that costs $580 (recently lowered) .. anyway, it looks like they're selling good low priced heatsinks..
𝘛𝘳𝘶𝘴𝘵 𝘺𝘰𝘶𝘳 𝘪𝘯𝘵𝘶𝘪𝘵𝘪𝘰𝘯
PC: ibuypower pre-built RDY Y70
Cpu: i9 14900K  Gpu: Zotac 4070 super ti  Ram: 32Gb DDR5  SSD: 2Tb
Case: HYTE Y70  MB: MSI 790-P wifi
Cooling: ibuypower 360mm RGB aio
Laptop: Lenovo Legion Pro 5i, u9 275HX, 32gb ddr5, 5070ti, 1tb SSD, 16" 165hz oled
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-383573
Yeah the Dark Knight is your best bet.
By any chance do you have something you can compare the dark nigh to by your own experience? Famous CM hyper 212 evo perhaps ?
CPU: I5 4670k @ 4ghz Motherboard: MSI z87 G45 Gaming RAM: 2x 4GB Avexir and Corsair 2x4gb ddr3 @ 1600mhz GPU: MSI GTX 1080 SeaHawk EK PSU: EVGA SuperNova P2 750w Boot SSD: Intel 320 120GB Storage: Crucial 256gb ssd and Samsung 250gb ssd
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-383996
My dad is running a hyper 212 Evo and from my experience with it the dark knight cools about 4-5c better, but of you get a hyper 212 Evo in push pull I think it would be the same.
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-384161
I'm liking the silverstone argon series cpu heatsinks. They're pretty cheap and look decent. I bought an AR02 to use in a very small mid tower case. I cant really provide any performance numbers on the one I bought tho. I can only say it seems good but it doesn't appear to have the largest area for cooling fins. Im also puzzled why they seem like such a reasonably priced item from silverstone. the company that also sells a computer case that costs $580 (recently lowered) .. anyway, it looks like they're selling good low priced heatsinks..
I will look more into those, I might wait on the cpu cooler, invest in something else to boost performance.
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-384468
How high would you be able to over clock an i5-3570k with the Evo 212?
It depends on the chip, some can go much higher than others. If you have a 3570K already then you can make your own thread and people can help you out.
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-384750
I know the phanteks PH-TC12DX coolers are in the $50-60 range and perform really well.
Review- http://www.techpowerup.com/reviews/Phanteks/PH-TC12DX/6.html
This cooler performs similar to the hyper 212 evo until you overclock then a big gap occurs
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-388923
Also the BeQuiet! dark pro 2 is on sale for $50 on newegg. It looks so good and is quiet.
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-389036
Cooler master hyper 212(25$) + nf-f12(25$)
the stock fan the hyper 212 is kinda loud so putting a fan worth as much as the heat sink on it seams to be the logical thing to do, right?
but rly it should be rly quiet and perform good enough
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-398936
They do? I cannot find it.
I'm sorry when I wrote that I was really tired I meant to say it was the normal one not the pro and it's at ncix http://us.ncix.com/products/?sku=80360&vpn=BK015&manufacture=be%20quiet%21&promoid=1316
https://linustechtips.com/topic/29602-best-50-cooler/#findComment-399037
