EPU, and TPU
Solved by Queek,
Hey thanks alot Queek! Just to reiterate, if I were to be running a 2 way crossfire, with cards that take external power I wouldent need the molex plug, but if I was running a 3 way crossfire with bus-powerd cards, a sound card, and a nic, then I probably should plug it in?
Yes that sounds reasonable. If you've got your system fully loaded, it won't hurt (and would probably help) to plug in that extra molex connector.
