I've been trying to update the firmware for my motherboard due to getting poor transfer rates on my drives.
The board is a Gigabyte GA-990FXA-UD3 REV 1.1 with the latest BIOS (F10e) and i can't figure out how to do it. I've downloaded
the driver from the website, it gives me a bunch of files that don't have anything to do with the chipset.
Any help?
The speeds below are what i'm currently getting on a WD Black 1TB running windows 7 64-bit
Read signature for full specs.
https://linustechtips.com/topic/295494-motherboard-problems/
Those read and write speed are not catastrophic, have u looked on the drivers website at all. Always good info there!
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/295494-motherboard-problems/#findComment-4011882
you might want to download the SATA drivers for your mobo
also for you mobo make sure you plugged the HDD to the SATA3 ports which are running from the AMD chipset and not the secondary controller
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/295494-motherboard-problems/#findComment-4014336
That's the problem, i've tried downloading the sata drivers, but it doesn't give me any way to install them.
and those speeds are best case scenario, after defragging for just under two days
the drives i'm using are all plugged into the native sata3 ports. The secondary controller is for the eSata ports on the back only.
https://linustechtips.com/topic/295494-motherboard-problems/#findComment-4019714
there should be a setup.exe file which is the installer for the drivers use that or use the update the driver under the device manager
https://linustechtips.com/topic/295494-motherboard-problems/#findComment-4022413
