So I just go into CS:GO(complete noob btw) and I started watching tutorials on finding your sensitivity. I tried doing the 360 thing from one end of my mouse mat to the other and I was never able to reach the same spot. I was always either before or after my start point.
Naturally I made sure acceleration was off in both the game and in windows. I even downloaded the markc mouse fix and I still had the same issue.
I have also tried surface tuning several times to see if it would help. I even went as far as to buy the Logitech G440 mouse pad.
Finally I borrowed my brothers Deathadder to make sure I wasn't crazy, and I'm not. The Deathadder was perfect every time.
For a mouse that advertises the most accurate sensor on the market. I am really disappointed.
So what to do next? RMA it? Keep it as is?
TL;DR: My G502 suffers from acceleration. Should I RMA it?
https://linustechtips.com/topic/295485-logitech-g502-acceleration-issues/
Is acceleration off in logitech settings?
yeah :(
have you tried using raw input?
yeah everything is set up properly in game. I tried using my brothers death adder and it was perfect.
I think it is an issue with earlier models of the mouse. Others have reported the same issues.
return that shit then.
