Have the following heatsinks, and I'd like to place them on the VRM's of the 780Ti board.
Only problem is, I'm not sure which exactly are the VRM.
Can someone please indicate where the VRM's are on this board.
I installed the kraken, but will now be remounting it due to worry of VRM temperature.
Gigabyte-GeForce-GTX-780-Ti-WindForce-3X
https://linustechtips.com/topic/295360-applying-heat-sinks/
dont just dont..... you need to strip off your cooler and... no just NO
those are for the RAM modules on the back side of the gpu, if there is no backplate to cool those then you use those
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/295360-applying-heat-sinks/#findComment-4010006
He said he was suing a kraken, therefor he would have already removed the cooler
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/295360-applying-heat-sinks/#findComment-4010036
hmmm but anyways those things are for the VRAM modules, not for VRMs
https://linustechtips.com/topic/295360-applying-heat-sinks/#findComment-4010038
They're really for anything that produces heat; I have a few myself that I use to cool my raspberry pi
https://linustechtips.com/topic/295360-applying-heat-sinks/#findComment-4010351
