Asus z97-ar
16Gb ram Hyper x savage 2400 cl 11
Pentium g3258
Asus r9 280x
evga 750w
Will only boot with one of the 8 Gb dimms in A_1. Get Red DRAM_light if i try anything else or boot loop. Have tried diffrent slots and mem ok.
Dont know what to do
Zorry, bad english --> From norway
https://linustechtips.com/topic/295176-help-plz-boot-problems/
Is the Ram placed one slot away from each other?        RAM stick | empty | RAM stick | empty
Double check your motherboard's instructions.
Hope you can boot up your system. :)
Desktop: i5 4670k, Z97-K, 16GB, MSI GTX 770, Evga 850G2, TT T31
Freenas Server: i3 4170, X10-SLL-F-O, Crucial 16GB UDIMM, 4x4TB WD Red, Evga 550GS, Fractal 804
Peripheral: K60, HyperX Cloud
Mobile: Nexus 6P
https://linustechtips.com/topic/295176-help-plz-boot-problems/#findComment-4007249
