Hi,
I have a problem when i try 4,7 GHz or 4,8 GHZ i get always bluescreens...
Settings for 4,7 GHZ are 100 x 47 and Voltage is 1,40
Settings for 4,8 GHZ are 100 x 48 and voltage is 1,41
Mainboard: SABERTOOTH_Z97_MARK_1
Ram 16 GB Ballistix-Sport-XT 1600MHZ
Cpu is watercooler (H110)
Should i go higher with voltage?
Regards
https://linustechtips.com/topic/294818-intel-g3258-overclocking-problem/
Don't go higher on voltage.
Hi,
Regards
each cpu's has it's max overclocking cap...yours is 4.6ghz mate :P
otherwise we would all rock or CPU's at 5hgz+
you voltages are stupidly high already...if you don't plan on using this chip for a long time i guess you could try 1.45v but this could (will) substantialy reduce the lifespan of your CPU..1.4v is already slowly killing it IMHO.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
What many people seem to forget is that not all the G3258 will automatically be overclockable to 4.8 GHz looks to me like you just reached the limit of your chip.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
Cooler should not cost more than cpu - Str_mape
You reached the limit of the chip.
Dear God why did you spend so much on everything else and dick out on the cpu? I have always hated the g3258, but this is stupid.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
Hi,
Regards
WHOA that voltage is dangerous.  I wouldn't go any higher than 1.36 volts.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
As it's a dual core it's lifespan is already pretty limited, so 1.4-1.45v is probably fine.
Although @ben89 should definitely be aware that anything over 1.30v~ will degrade the chip and limit the lifespan with anything over 1.40v causing quite a bit more deterioration.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
I had intel xeon 1230v3 on it but sold it now because i want to upgrade soon to 2011-3
@othersiders i just ask because i saw people playing bf4 with 4,8GHZ and voltage was 1,45 or even 1,50...
1.4V is the general limit on Intel's Ivy Bridge and Haswell CPUs.
if you don't mind frying the chip go ahead for higher voltages...but your current values are already pushing it real hard mate.
I suppose, but still that's getting pretty risky.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
yeah but at 1.5v+ the lifespan can often be in the orders of a couple hours only...
You shouldn't have a problem running BF4 at your current clock speed.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
Well it looks like you got unlucky with the Silicon lottery.
