Hi, am a guy from INDIA. we dont actually hav forums and gaming build guids or custm gaming or professional pc build guides over here. i just need help to buid my own 1080p Gaming and Designing pc. Thanks, to online shopping sites that now we atleast have access to a lot of hardware. that we were not having earlier.
I have picked the following parts with the room to upgrade in future:-
MSI Z97 Guard Pro Motherboard
Intel 3.1 GHz LGA 1150 i5 4440 4th Generation Processor
MSI AMD/ATI R9 270 Gaming 2 GB GDDR5 Graphics Card
Kingston HyperX FURY Memory DDR3 8 GB PC (HX318C10F/8)
Seagate Barracuda 1 TB Desktop Internal Hard Drive (ST1000DM003)
Kingston SV300S37A/120G Internal Hard Drive SSD
Corsair SMPS CX500 500 Watts PSU
Case-Corsair carbide spec-01
Peripherals :-
BenQ GL2450HM 24 inch LED Backlit LCD Monitor
Thrustmaster Dual Analog 4 Gamepad (For PC)
Cooler Master Devastator Gaming Gear Combo USB Keyboard
https://linustechtips.com/topic/294451-first-build/
Looks good to me,
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/294451-first-build/#findComment-3998407
Gte the spec 02 instead of the spec 01 its only about $7 more expensive and has ssd mounts, tool free pcie slots and another fan, and get something like an fx 6300 and gigabyte 970ADSP mobo so you have money for a better gpu like the 960
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/294451-first-build/#findComment-3998922
