I am planning a build and need some cpu help. I want a cpu good for me, but don't wanna overspend. Here are my requirements:
-Gaming
-Moderate programming (unity and some c++)
-Daily use
I am biased towards intel for some reason(probably the Linus ads)
Once again, cheap but gets the job done.
https://linustechtips.com/topic/293632-what-cpu-is-for-me/
Do you have a budget for the CPU?
Id'e recommend a 4690K, or a 4790K.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/293632-what-cpu-is-for-me/#findComment-3986687
Uuuh less than $200 but I'm more focussed on the cheapest cpu that meets my needs. I might add i don't plan on OCing it
well then a I5- 4440
https://linustechtips.com/topic/293632-what-cpu-is-for-me/#findComment-3986731
Is it worth the extra $100 for the 4790?
unless you are planning on using one of the latest high end graphic cards, than no.  (even then not really for single gpu gaming).
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/293632-what-cpu-is-for-me/#findComment-3986778
id say the cheapest non k i5 that's still quad core is the best for you. something like this http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116942 or http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116895
CA-RIP, Cz up hoes down, bang these hoes out with my rounds.
https://linustechtips.com/topic/293632-what-cpu-is-for-me/#findComment-3986803
xeon 1231 v3, great for the price compared to the core series if you aren't going to overclock (and it seems to me that you don't need to :))
yeah, this is another very good option. can't go wrong with a better binned, non-K i7 cpu for cheaper.
https://linustechtips.com/topic/293632-what-cpu-is-for-me/#findComment-3987145
