How to?
Go to solution Solved by failblox,
Yeah LED strips are pretty much the way to go.
Custom water loop.
Custom pain job on case and/or some components.
Matching colors and LEDs.
Excellent cable management (with custom sleeved cables).
Also, you're supposed to put the LEDs somewhere where you won't see them directly, because if you did, they'd be wayyy too bright and it'd be uncomfortable to look at.
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/293574-how-to/#findComment-3985995
Looks like some sort of combination of UV light and paint
https://linustechtips.com/topic/293574-how-to/#findComment-3985996
Custom water loop.
LED ropes something like this?
http://ipon.hu/webshop/product/aurora_12v_dc_single_colour_flexible_led_strip_light_5m_au_st100w/723881
https://linustechtips.com/topic/293574-how-to/#findComment-3986022
That PC doesn't look amazingly fancy, to be honest. Looks like UV lightning with some UV reactive cables.
https://linustechtips.com/topic/293574-how-to/#findComment-3986023
~Slick
https://linustechtips.com/topic/293574-how-to/#findComment-3986042
A case with an area for cable management will help greatly.
https://linustechtips.com/topic/293574-how-to/#findComment-3986236
