BootMgr Problem,
Go to solution Solved by ProKoN,
can you confirm these two settings in uefi under the boot menu
hard drive bbs priorities - your ssd should be set as #1
boot option1 = should be set for your ssd
Hello!
I'll put my specs then cut to the chase.
Intel G3258
MSI Z87-G41
G.Skill 8gb RAM
GTX N660 MSI
When I boot up my computer, the MSI logo comes up and says to hit F11 for boot menu or DEL for the BIOS. If I just let it run, I get the BootMgr error and to press cntl + alt + delete. I tried to go into the BIOS and make my SDD which has windows on it priority, but its not listed. Going back to the logo and two options, if I hit F11 then a menu comes up and I can select my SSD. Then windows will load up just dandy and no problems. My question is is there a way to make it so it goes straight to windows instead of me having to open up the boot menu, or not? Its only a minor inconvenience, and not terrible if I have to select the boot menu everytime.
Thanks,
Alex
CPU: G3258 @ 4GHz GPU: Gigabyte GTX 960 OC RAM: 8GB G.Skill DDR3 1600 SSD: Corsair LS 120GB Case: Antec GX500 Mouse: Logitech G402 Keyboard: Razer Blackwidow Headphones: Shure SRH440 Microphone: That Zalman Zm-Mic1 that everyone recommends but noone uses
Remember when the R9 280 was the HD 7950? Pepperidge Farm remembers.
Running two AMD Cards: https://www.youtube.com/watch?v=rCwn1NTK-50
https://linustechtips.com/topic/293453-bootmgr-problem/
try a different sata cable
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/293453-bootmgr-problem/#findComment-3984689
Switched it out with my HDD, same issue.
https://linustechtips.com/topic/293453-bootmgr-problem/#findComment-3984708
Put in your install disk or USB and run system repair.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/293453-bootmgr-problem/#findComment-3984727
https://linustechtips.com/topic/293453-bootmgr-problem/#findComment-3984776
